2024 Technology Preview Program
Opening Rhino Files causes crash
This is a new install on OSX and I am a first time user. I am moving from Rhino to ArchiCAD so need to open Rhino files in ArchiCAD. Upon completing the loading process the file closes every time. I have experimented with opening Rhino files of various complexity and they all crash. Any hints of what to try would be a help.
Thanks!
Minh Nguyen
Thank you for the report and I am very sorry about the experience!
Could you clarify a bit more about this part: "Upon completing the loading process the file closes every time"? Does Archicad crash - meaning, close completely and the Bug Reporter appears, or Archicad only shows an empty grey screen? If the later is the case, I believe you were trying to open a Rhino 6 file in Archicad. Unfortunately, they are not yet supported. At the moment, Archicad can only read Rhino 5 files.
But if Archicad crashes totally with a Rhino 5 file, could you share with me a sample one for in-house testing? Please let me know if you'll need a secure place to upload it!
Best regards,
MInh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thanks for your reply. It is a Rhino 6 file. So that is probably the problem. I will back save them to V5 and try again. No, it is not a crash, The program remains active but all windows for the file opening process disappear from the desktop as if nothing happened. Will be back in touch if the back-save solution does not work.
Thanks again.
