‎2008-08-29 09:18 AM
‎2008-08-29 10:34 AM
‎2008-08-29 11:02 AM
‎2008-08-29 11:13 AM
‎2008-08-29 11:28 AM
‎2008-08-29 11:36 AM
‎2008-08-29 11:57 AM
adzik wrote:By a bug. I was asking this to check whether the object is incorrectly programmed.
I'm not sure I follow you correctly.
How can the 3D front view be the same if their orientation is different?
Before changing the value the front views worked. The situation in the posted jpg only appeared after changing the values and not only on that particular door but on all the doors with changed values.Changing what value? Did you change a parameter? Or some setting in the listing Dialog?
‎2008-08-29 02:26 PM
‎2008-08-29 03:16 PM
‎2008-08-29 03:27 PM
