PLT -> PDF converter for Mac OS X
So anyone knows if there's a program for OS X that'd convert PLTs to PDFs?
13 REPLIES 13
Sounds easy. I tried it and got nothing. Any special tricks or just use the "Open" command
David Maudlin
larrymac:
Make sure that the Enable pop-up at the bottom of the Open dialog box is set to All Files (or HPGL File).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thanks for the suggestion. I was actually getting an error on open, sorry for the lack of proper information. See screen grab of error message...
I also tried the earlier suggestion of using Graphic Converter. It does give me something to look at but rather garbled and all text is backwards. Maybe I received faulty .PLT files?
-Larry
David Maudlin
Larry:
That would be my guess. You could have the files resent, I usually zip files as this seems to help them get through the internet in better shape. Or depending on your needs, a different file format might be more useful.
