Please Help me Reg Archicad Database in Calculation Menu
Dear Archicad User
I am working with Archicad Database in Calculate Menu. very complicated stuff how to proceed mechanically calculations , I linked with elements to database through properties i have given properties in wall elements in Criteria example : my database Commponents entry only for particular area size suppose if area will increase how to show output for current area please guide me . It will take automatically or we have to manually entry ?
please guide me
regards
1 REPLY 1
please guide me
I'm sorry that we have a language barrier here, as I can not really tell what your question or problem is from your description.
It sounds like you have set up a property object to generate a fixed-size component, rather than making it proportional to the linked wall's surface area.
You may also want to look at Eric Wilk's new book "ArchiCAD From CAD to Quantity Survey" - http://www.fc-cadlink.com - although I should warn you that the English translation is quite poor, so if you can read French I would get that version.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
