2004-10-15 04:18 PM
2004-10-18 02:25 AM
2004-10-18 03:20 AM
Please tell me I'm the most stupid Mats in Sweden and I can sleep a little better...You'd only be the most stupid Mats in Sweden if you moved your origin before reading those x values. Without testing it, I can only imagine that there is a remote possibility that using different Master Layouts each time you saved DWG's could change the origin? Or maybe the placed drawing moved somehow? Wild guesses after enjoying a Bundy rum nightcap - might be worth waiting for other responses!
Within ArchiCAD if you are drawing too far away from the origin errors start creeping inAt 14 metres, it shouldn't be a problem.
2004-10-18 01:02 PM
2004-10-18 05:13 PM
AndorSzoke wrote:Thank you Andor!
I have an idea why this is happening, please check it.
In AutoCAD there is an absolute origin but you can specify a user origin (UCS command). When a user origin is set normally you can see as if the user origin would be the only origin. So before the Architect inserts your drawing he should try to set the origin back to the absolute origine:
UCS <enter>
WORLD <enter>
ArchiCAD always imports drawings based on the absolute origin of the DWG file.
AutoCAD always places xrefs on its user origin.
I hope this helps.
Regards
