License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Plotmaker 3.1
I want to know how can I transform a Plotmaker 3.1 file into a DWG file?
5 REPLIES 5
Either save dwg from opened particular drawing, or publish to dwg.
BTW- this should go to the "Construction Documentation" folder in the forum...
Best Regards,
Piotr
TomWaltz
Really? I would have though "Data Exchange and Information Sharing"
Tom Waltz
Thank you for your answer Piotr but I think it is not possible to save as dwg from PlotMaker 3.1 as it was possible in the previous versions. Neither to publish as dwg from Plotmaker.
To transform to dwg direct from ArchiCAD is easy but from Plotmaker I don't get it.
Best regards,
Hernán
Djordje
You can't Save As, just publish.
Refer to the Graphisoft Documentation folder, where you have a detailed PDF - DXF DWG conversion guide.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thank you Djordje. I finally got it.
Nan
