2021-08-12 04:07 PM
Solved! Go to Solution.
2021-08-18 02:04 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-08-12 08:22 PM
2021-08-13 05:14 PM
2021-08-13 05:48 PM
LaszloNagy wrote:This had us scratching our heads. Thanks for forwarding it to GS. Given you don't have the US version, I am wondering if anyone else has seen this issue.
Based on your description I would say it is definitely something in the Translator Settings that is causing this.
My first tip would be that the two Translators may not save to the same AutoCAD version.
Unfortunately, I do not have the USA version installed, and the INT version does not have this DUMMY Translator by default.
But I will forward this to GS HQ and let them figure it out.
2021-08-16 02:48 PM
This is why, with this option activated by default for DWG for Dummies translator, the objects will be exported to DWG using their default parameters from Archicad.Use this option to create fewer blocks, by converting all instances of a particular library part into a single DWG block. The resulting block will use the ARCHICAD object’s default parameters. Customized object parameters are therefore lost.
Exception: Annotation elements, labels, windows, doors and construction elements are not affected by this option. All instances of such library parts are exported separately.
Minh Nguyen
GRAPHISOFT
2021-08-16 03:32 PM
2021-08-18 02:04 PM
Minh Nguyen
GRAPHISOFT
