Point 0 and North setup for BCF comunacation
I'm trying to set up communication workflow based on BCF. What I have noticed that BCF saved either from Kubus or Markup tool are not influenced by North setup in Archicad.
After import to DDS or TeklaBIMsigth viewpoint, form comments show different empty space nearby the model. As it turned out IFC is turned according to North angle set up in AC. BCF, however, is not influenced and shows point as it was saved in model coordinates.
Is there any way to make it work properly?
I have a small workaround in mind. So we set up north to 0 in building models and export them for clash detection purposes. And for a final model, we adjust the angle with survey point to match building with the site model.
Thanks, Erwin It was a good idea. Working workaround for this issue is to adjust the rotation of survey point GDL object to True North value then BCF is saved with proper orientation.
Erwin Edel
Have you talked to their support? http://www.bimcollab.com/en/Support
Kubus' support on ArchiCAD is top notch for the subscribers, so I would just ask them for help.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Not yet, this was the first place I thought of. I supposed that someone had this problem before . I have sent ticket we will see how they can help. Thanks for the suggestion.
