ā2007-01-24 01:11 AM
ā2007-01-24 01:12 AM
ā2007-01-24 04:12 PM
ā2007-01-24 04:35 PM
Stress wrote:
..I can't figure out how I did it as this parameter doesn't exist in the available list. I'm trying to use it again on another project and can't. (in AC9)...
I'm using Cadimage D/W builder windows...
ā2007-01-24 06:02 PM
Dan wrote:I think your right... the parameter doesn't exist. Is assigning a different parameter an easy task? I shy away from any GDL scripting
Notes/Remarks is added as an addtional parameter from the "ArchiFM & Listing Parameters" of any basic Archicad window. This additional parameter may not exist in Cadimage D/Wbuilder windows...if it doesn't, you'll need to assign a different parameter for this purpose.
ā2007-01-24 09:08 PM
ā2007-01-24 09:09 PM
ā2007-01-29 06:53 PM
henrypootel wrote:I'm at a loss trying to get a Cadimage schedule to look like this: (pretty basic)
Hi
Assuming you are using all Door and Window Builder items, the notes you are using are probably the ones in the first screenshot. If this is the case, you need to use the Door and Window Builder schedule to schedule them (2nd screenshot). The process for doing this is detailed in the Door and Window Builder help file under 'Door and Window Schedules'.
ā2007-01-29 07:30 PM
Stress wrote:henrypootel wrote:I'm at a loss trying to get a Cadimage schedule to look like this: (pretty basic)
Hi
ā2007-02-06 06:53 AM
