Problem with Wall builder?
Hey I've created my model, insterted windows using window/door builder. I than create the bricks for my wall using Wall builder. Afterwards I've realised I want to change something so I have then modified my opening/wall and re-applied wall builder. However for some reason there is like a gap now between the sill bricks and the wall bricks that wasn't there before and I don't know how to change? When re-applying the wall builder bricks it keeps doing the same thing, Am I missing something here?
4 REPLIES 4
It'll help if you say what version of archicad you're using and on what operating system etc…
J
Oh yeah sorry, Archicad 12, Cadimage tools, XP.. NZ
Djordje
Just put those in the signature ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Check to see if you have set the Openings/Margins to zero for cladding and trim. Also make sure you do not have "Apply to sill" selected in the Openings/Trim/Jamb menu. See attached.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
