Hey I've created my model, insterted windows using window/door builder. I than create the bricks for my wall using Wall builder. Afterwards I've realised I want to change something so I have then modified my opening/wall and re-applied wall builder. However for some reason there is like a gap now between the sill bricks and the wall bricks that wasn't there before and I don't know how to change? When re-applying the wall builder bricks it keeps doing the same thing, Am I missing something here?
Check to see if you have set the Openings/Margins to zero for cladding and trim. Also make sure you do not have "Apply to sill" selected in the Openings/Trim/Jamb menu. See attached.
Gerald Hoffman āThe simplification of anything is always sensationalā GKC Archicad 4.55 - 29-Latest USA 2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
