Hey I've created my model, insterted windows using window/door builder. I than create the bricks for my wall using Wall builder. Afterwards I've realised I want to change something so I have then modified my opening/wall and re-applied wall builder. However for some reason there is like a gap now between the sill bricks and the wall bricks that wasn't there before and I don't know how to change? When re-applying the wall builder bricks it keeps doing the same thing, Am I missing something here?
Check to see if you have set the Openings/Margins to zero for cladding and trim. Also make sure you do not have "Apply to sill" selected in the Openings/Trim/Jamb menu. See attached.
Gerald Hoffman “The simplification of anything is always sensational” GKC Archicad 4.55 - 27-6000 USA 2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
