Yvonne
Problems with adding points to mesh
Been using the space bar to pick up contours on a mesh but half way through it won't let me do it. Is this the polygon count thing....if so, is there a work around?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
12 Replies 12
Can you show screenshots that show how you are doing this?
I would also be interested to see your settings in the Mesh Settings Dialog and the Info Box as well. These may give a clue to the origin of the problem.
Guru
Are you able to manually add contours?
Yvonne
I think you're right that it might be corrupted. We couldn't find a quick fix or work around and we don't need that mesh anymore so all good until it happens again...
