Property Expressions Help
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-01-22 04:22 PM
2019-01-22
04:22 PM
I really need some guidance regarding the property expressions available in Archicad 22.
I am attempting to 'SPLIT' the 'Nominal W x H Size' property of a door to only display the leaf width.
However, no matter what I do, the only result is 'x'. (See the attached screenshots).
I have followed the reference guide tutorials exactly, but to no avail.
The most confusing part is that changing the 'delimiter' value to something other than "x" doesn't change the result. Neither does changing the 'PartIndex' value.
What am I doing wrong?
Labels:
- Labels:
Data management
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-25 12:24 AM
2021-05-25
12:24 AM
Very interesting, that if you are not using SPLIT command, just 'Nominal W x H Size' - it still shows you 'x'
If you just need leaf width, why not to extract parameter directly from door object in schedule?
Now how to do it. You need to extract variable that called 'gs_leaf_panel_witdth'. By default this parameter is hidden. So, you need to open a door as Library Part and click on the red cross next to this variable. Then save a door with new name into Embedded Library (after everything is completed, you can delete this file).
After in Schedule Scheme settings dialog you need to click on the arrow next to the button "Fields" and choose "Library Part Parameters". In new window that shows list of available libraries you need to find your temporary door and search for 'gs_leaf_panel_width' and click on 'Add' button.
Now ArchiCAD can extract this parameter from each door (because they are using the same variables names).
After new schedule is set - you can delete the door from Embedded library.
