2005-04-06 03:32 AM
2005-04-06 01:05 PM
2005-04-06 04:09 PM
2005-04-06 05:31 PM
Paul wrote:I believe there is a problem with the import. We were getting errors and blank files when opening a dwg file created from plotmaker. But when I opened the file on our PC with Autocad the file came in correctly.
I suspect it is not the importing that is the problem, but the exporting - because AutoCAD cannot open them either
Exporting layouts to dwg used to work under 8.1 with no such issues
and it works fine under 9.0 for all other formats except dwg & DXF
Can anyone else duplicate the problem? - remembering the DWG must be as published from a Plotmaker layout rather than direct from a ArchiCAD/Plotmaker drawing
Hope someone can help!
Cheers
Paul
2005-04-07 02:18 AM
2005-04-08 10:16 AM
