ā2007-02-03 01:47 AM
ā2007-02-04 07:19 AM
ā2007-02-06 06:13 AM
ā2007-02-06 06:24 AM
Bala wrote:See attached
where do I find the " merge to one PDF file" command?
Bala wrote:Still waiting for a fix.
. Although I came across some discussions about this topic I did not see a proposed solution.
ā2007-02-06 05:52 PM
ā2007-02-06 07:05 PM
Bala wrote:You don't need to open Grab. You can used Command-Shift-4 to screen capture an area (click and drag to select the area, or press SPACE to pick an entire program window/palette) and Command-Shift-3 to capture the entire screen.
I would show you this clip except I do not have a screen capture software. The Mac's 'GRAB' software does not work because the AC 10 window does not remain on screen when I activate GRAB. What is the name of your screen capture window?
ā2007-02-06 08:42 PM
ā2007-02-07 06:06 AM
ā2007-02-07 04:43 PM
ā2007-02-07 06:19 PM
