Publisher Set
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-02-03 01:47 AM
I am trying to create a Publisher Set in PDF or DWG format that I can e-mail to my consultants. In the Organizer window I drag a layout sheet from the Layout Book to the Publisher Set. Then I click on the 'Publish' button at the bottom of the Navigator.
A Publisher Set Properties window pops up. I select the Save Files for the Publishing Method. Then I click the 'Browse' button to select the folder in which to save the Publisher set. Then I select the 'Create flat file structure' and click OK.
Then I highlight the recently transferred file in the Publisher Set and click on 'Publish' button at the bottom of the Navigator. A Publishing window pops up top show the file being save to the destination folder. It also show the size of this file.
Finally when I try to open this file in Adobe Reader (7.0.5) and an error message pops up - " ....not a supported file type or because the file has been damaged..." When file icon is highlighted it shows the file size to be zero. I get the same result no matter which Layout with content I save to the Publisher Set.
I also tried this in DWG format. I was able to open the Publisher file AC10 but it was empty.
I got the same results when I tried after restarting the computer.
Appreciate if anyone have a solution to this problem.
- Labels:
Data Exchange
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-04 07:19 AM
It's a bug. Do a search for: zero k pdf ... it's been discussed.
Red Canoe Architecture, P. A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-06 06:13 AM
I also tried searching for the keyword " zero k pdf". Although I came across some discussions about this topic I did not see a proposed solution.
Bala
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-06 06:24 AM
Bala wrote:See attached
where do I find the " merge to one PDF file" command?
Bala wrote:Still waiting for a fix.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-06 05:52 PM
Thank you once again for responding. After clicking on 'fix' link I am glad to discover that the problem is not related to the Mas OS since mine is OS 10.3.9.
I am puzzled why the option 'merge to one PDF file' is not available on my window. Instead I see in its place, 'crop image to zoom' option but this grayed out.
I would show you this clip except I do not have a screen capture software. The Mac's 'GRAB' software does not work because the AC 10 window does not remain on screen when I activate GRAB. What is the name of your screen capture window?
Bala
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-06 07:05 PM
Bala wrote:You don't need to open Grab. You can used Command-Shift-4 to screen capture an area (click and drag to select the area, or press SPACE to pick an entire program window/palette) and Command-Shift-3 to capture the entire screen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-06 08:42 PM
Do you have the Folder (containing the PDF's) highlighted? See the Arrow on previous attachment.
...what Tom said on screen shots.... or you can also use the "timed screened" capture with "Grab".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-07 06:06 AM
The 'merge' message did show up when the file was highlighted. However I got the same result. See attached composite. One shows the PDF file size when being 'Published' to a folder. The second shows the saved file in the folder having 'zero' value when highlighted. I get error message when I try to open it.
I have the latest AC10 update as far as I can tell.
BTW the screen saver command is much better than trying to use the GRAB.
Thanks.
Bala
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-07 04:43 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-02-07 06:19 PM
I will try out the posted solution within the next couple of days and let you know how it worked out.
Thanks.
Bala
