Perhaps I need to explain what it is I'm trying to do.
I have a Layout book sheet, comprised of 3 floor plan view (lifesafety, accoustical, floor plan), some reference items, and a title block. The 3 drawings are set to display at 1/4" = 1'. Now when I publish as a DWG, it keeps that same scale, 1/4" = 1' (so as, when I measure an 8' wall in Autocad to check for accuracy it shows me that the wall is 2", which is correct.).
However, my issue is this, I need to be able to publish this Layout Book sheet to DWG, and when measuring that 8' wall for accuracy, it actually measures 8' and not 2" (which would be the 1/4" = 1' scaled factor).
Now, if I publish from the View Map or Project Map, it works as I need it. But then I do not get all the items I have built up in my layout book, along with the zoomed views that I need for this particular area of the building.
Any steps on how to achieve this would be appreciated. It seems as though it could be an average thing to accomplish, perhaps I am just missing the boat? I also understand the scale tool in autocad, however, I am really looking for a way to do it in the publishing process with Archicad.
Thanks!
