2010-09-01 04:14 PM
2010-09-01 04:29 PM
2010-09-01 04:51 PM
2010-09-01 05:01 PM
2010-09-01 05:14 PM
2010-09-01 07:53 PM
2010-09-02 01:47 AM
Master wrote:Master Script is right. Anything and everything related to list schemes, including the database, criteria, etc., is all stored externally in the List Templates 13 (e.g.) folder. The criteria are in LISTCRIT.TXT
I believe the criteria list is stored in the folder Database of your locally stored library. Load the databases of the previous (13) library instead of the current (14).
2010-09-02 09:51 AM
2010-09-02 06:27 PM
Achille wrote:Criteria, etc are all part of List Schemes ... the "Calculate Menu" function. Typically, a list scheme is what reports the information that is generated by the Property objects that are associated with elements according to your Criteria.
Actually, I was not asking about List Schemes... I was asking about Links of Properties to Criteria. Those are stored inside the Calculation DB which i have stored inside my library folder.
I think that the Links of Properties to Criteria are saved in the file db_CRIT.LIC (see attached image)
The strange thing is, that with the same library loaded on both files (13 and 14) and with the same DB selected, i get a longer list of links in the AC 13 file than the AC 14 file... how is this possible???
2010-09-03 01:31 PM
