QuickSilver trick (OS X only)
Eduardo Rolon
I just ran into a Quicksilver feature that lets you launch another instance of a program without having had to make a copy of the application so we can copy/paste between different files.
This eliminates having extra copies of the AC app in the application folder.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
20 REPLIES 20
Rod Jurich
Dwight wrote:
am trying it now.
Can you post the URL, Dwight. Google has failed me this time.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Eduardo Rolon
http://quicksilver.blacktree.com/
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
two more post to...
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
My 300th
AC29 US/INT -> AC08
another Moderator
Rod Jurich
Thanks Eduardo.
Rod Jurich
Eduardo Rolon
And some QS usage links
http://quicksilver.blacktree.com/docs/?page=Quickstart+Guide
http://vjarmy.com/archives/2004/03/quicksilver_a_b.php
http://www.43folders.com/quicksilver/index.html
AC29 US/INT -> AC08
another Moderator
Rod Jurich
Eduardo, again many thanks. All my ArchiCAD copies are now in the round file. Works a treat.
Rod Jurich
Eduardo, thanks for the great tip.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Here is another quick launcher for MAC OSX
Show scripts icon on the task bar using apple scripts utility in your applications folder. Then Place aliases to your frequent applications (Or in a folder name?) inside your user scripts folder under home/library/scripts. A click on the scripts icon will reveal all.
Aussie John
you can do that already in address book
Cheers John
[/size]
