Raster to Vector
Petros Ioannou
Hi all,
I am looking for a raster to vector app since there is a need to convert multiple scanned drawings.
There are too many options on the net but which is more suitable for architectural drawings?
thank you
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
7 REPLIES 7
I've used raster 2 vector in the past with good success.
http://www.algolab.com/r2v.htm
The trick was to prepare the pdf of image for scanning as it converts everything it sees to dxf! and that includes text etc. Avoid fat lines, shading or hatching on the target image.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Another one that looks promising is Scan2CAD. I have not used it myself but I learned about it from a brochure that came in the box with a new HP Designjet. They have a very polished website, videos and 30 day trial. Plus the price is very reasonable for what it does. $250 US ($400 Pro).
http://www.scan2cad.com
Not as affordable as Raster 2 Vector but you may want to investigate both and see which is the better investment.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Petros Ioannou
I've already checked the Scan2Cad trial version but I can't say I'm exited.
32 GB 2400 MHz DDR4
Sam Wheatley
try this.....WinTopo Freeware, Software for raster to vector conversion. ...
www.wintopo.com/dl-wintopo.htm
ArchiCad 26 US
IMac Pro
iMac 3.2 GHz Intel Core i5 16 GB
NIVIDIA GeForce GT 755M 1024 MB
Thomas Holm
Adobe Illustrator will do it. It will also save as DWG if needed.
Vextractor may help convert raster drawings to vectors (DXF), especially for not very good-quality scans.
http://www.vextrasoft.com
Petros Ioannou
thank you for your input.
32 GB 2400 MHz DDR4
