ā2005-09-15 06:33 PM
ā2005-09-16 09:16 AM
ā2005-09-16 10:44 AM
Achille wrote:No, it does not have to be DXF.
yes you can... it has to be dxf, and in the translator setup you have to choose in the "open options" translate autocad blocks as library parts and 3d data to GDL script
ā2005-10-13 07:41 PM
ā2005-10-14 06:56 AM
James wrote:If you can export the file using IFC, then you will be able to work on it in ArchiCAD. Watch out what are you exporting the file from - various versions of Autodesk software have various limitations on IFC export/import. ArchiCAD has IFC 2.x; if the plugin is not in the original installation it is on the Graphisoft Web site.
I have a file in .max and .dwg format containing 3D information. I want to open the file in ArchiCAD 9. I don't want it as library parts, I want the information to be the base information for a project that will be worked on for months that will need to be constantly manipulated.
Is this possible without, totally breaking down the orginal file into tiny parts and bringing it in one at a time. If it is not possible, then why does ArchiCAD not work better with other file formats considering its marginal position in the market share.
