Room Finish Schedule
kevin b
Currently, we have custom fields in our zone stamp for wall finishes (NSEW), so that the finishes can show up on our schedule. These finishes though are manually entered into the zones. Is there a way to extract this info from the model? There should be but I can't seem to figure it out. The zones themselves can do it because I can select "Inheret Boundary Wall and Trimming Element Materials" and they show up correctly in 3D. So how can I extract that info to a room finish schedule? Seems like it should be easy. Seems like it is the proper workflow, so that you modify the model (wall materials) and the info (that's the I in BIM right) shows up in a schedule.
What am I missing such that we need to find work arounds or GDL gurus to do this sort of stuff. Would be really nice if it was truely interactive, so that if I change the material in the schedule it would changethe model but I know that's just crazy talk.
Any help would be appreciated.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
17 REPLIES 17
kevin b
Steve, I appreciate all the input. I need a schedule like the screen shot I posted. The work arounds of tring to use wall IDs, etc would be more work than just manually entering the info into the zone stamp, and how do you ID one side differently from the other, a North Wall in on room is the south wall on the other side.
Every firm I've worked at and most drawings I've seen from other firms, at least those doing commerical work in the northeast have a finish schedule more or less like this. Rooms listed by name and number, 4 walls differentiated by direction, floor, ceiling. Some have more info some less but that's the basics. It shouldn't be so hard to get something useful for something that is so common, especially given that the parameter is somewhere, the zone can extract that info by clicking the inheret button, so why can't I find that parameter somewhere to put on a schedule.
Thanks again for trying.
kevin s burns, AIA
massachusetts, usa
Windows 10
Erika Epstein
Using room Identifier_NCS 14 I created a schedule using fields some that are read directly from the zone, others from filled in parameters.
They can be changed in the schedule or in the zone settings individually or in groups.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
here's the pic
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
kevin b
Erika>the attached file is no longer available, but it looks like what I have and from the sounds of it you are filling in some of the parameters (wall finishes/N, etc), in the zone, same as we are. It's good, just seems like it should be better.
kevin s burns, AIA
massachusetts, usa
Windows 10
Erika Epstein
Kevin,
I agree, it is not an ideal solution.
If you have a physical baseboard, you can call its material, but even that is not a complete solution as you are still stuck with the orientation problem.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
the orientaion problem goes away when you use a wall ID.
Too many times N,E, S, W is not enought anyway. Rooms may have several walls in each direction, or walls that are rounded, on angles, etc...
If you want to have the wall material inherited by the zone from the walls displayed, try the listCodeWallMat parameter. You can verify it in 3d window. The sides of the zone will have the schedule assigned material.
This will display the inherited wall material in the scheddule and give you a tab to click in the schedule that will open up the materials/fills window.
You will need to click on the wall finish first to see the tab/arrow.
You can select what ever material you want and it will change the material inherited from the walls.
By null at 2010-07-29
This is still not what is needed in a room finish schedule, but forget about trying to extract that from a zone with out some additional gdl scripting.
If you don't want to do that, quit trying to extract that data from a zone.
Do you really want a roof finish schedule?
Put some useful schedules next to your interior elevations and you wont need a room finish schedule.
DaveOlufs
KevinB...
In other words, do it manually. There seems to be no flexibility or really capabilities with scheduling unless you have years of education and programming experience. To get it done 'right' you must do it manually or fake it until you make it.
I don't have time to figure out AC schedules to be frustrated the output and information is inadequate or minimal.
From a scheduled response...
Dave Olufs
Just 4 Measure, Ltd
iMac Pro 3.2GHz Quad, 32GB, OSX 10.13.6, AC-5, 6, 6.5, 7, stopped for a few years--started again with 12 thru 17, 18 or 19 didn't work, then 20, 21, now skipped to 23. Started in 1976 hand-drafting ink on mylar...
