2007-02-22 10:17 AM
2007-02-22 10:53 AM
2007-02-25 01:09 PM
2007-02-28 09:26 AM
2007-02-28 01:50 PM
2007-03-02 11:00 AM
2007-03-02 04:45 PM
laszlonagy wrote:Ok, I've made some boxes in autocad (as shown on the pic). Saved as an autocad2004 format.
After you open the DWG file as a GDL object, you will be in the Library Editor Window.
Can you post a screenshot of what is there in the 3D Script Window and the 3D View Window of the Object?
2007-03-02 04:56 PM
2007-03-02 05:06 PM
Andrew wrote:Doesn't that only import the 2D part?
Easiest way I have found is simply to drag a DWG into the appropriate plan view.
2007-03-02 08:41 PM
