2020-04-26 06:51 AM
2020-05-05 11:03 AM
Jeff wrote:Hi Jeff,
I appreciate all your help Gerry. That sound like a deal breaker though...as I imagine changing the units in all tables would have unwanted consequences...
What I still don't understand is why the property values get added together for identical items when the property is an expression. The schedule clearly does NOT add together the values that are returned by the basic 'Width' and 'Length' parameters, even with the 'Merge Uniform Item' option checked. It only happens in the column driven by the expression.
I would have expected the schedule to not know the difference, and not discriminate between data returned from the basic property 'Width', and data returned from the exact same element attribute delivered through the use of an expression simply pointing to that very same property.
ie: If 'Width' = 10, and 'Expression (Width)' also = 10...why does the schedule multiply 'Expression (Width)' x 'Quantity', but not 'Width' x Quantity?
Perplexing...
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-05-06 11:35 AM
Minh Nguyen
GRAPHISOFT
2020-05-06 03:18 PM
2021-05-04 08:00 PM
