Hi there
What you are doing is right. Nevertheless you have to take in account that if the Schedule is saved as a View in the View Map, those Dimension units may be saved in meters. If that is the case just change the settings of the View.
Remember to check under
Preferences / Dimensions
, all the options : l
inear dimensions,
sill heights dimensions, and window and door dimensions.
Check
Calculation Units
too, those will calculate some of the dimensions for objects, like in your case, the sill height.
Hope this helps
Nando Mogollon
Director @ BuilDigital
[email protected]Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
