2021-08-19 02:42 AM
2023-01-23 05:24 PM
Hi All,
I was having the same issue, and Joskule's answer helped me!
I don't think this is caused by a bug, but a new feature that defaults to this behavior. Since Archicad 25 you have more control over merging values (e.g. you can merge IDs into a single cell, and they will all be listed in the merged cell, separated by commas). This is the only material I found about it:
https://help.graphisoft.com/AC/25/INT/_AC25_Help/005_NewFeatures/005_NewFeatures-18.htm
So, if you list your values as usual, but as an extra step, click this icon next to the header of the field, and change it to only merge identical items, it should work as it used to (at least it did for me).
Regards,
2025-01-28 04:36 PM - edited 2025-01-29 02:33 PM
Any news on fixing this issue?
Archicad 27 is still not merging items correctly when the schedule contains custom parameters from objects.
EDIT: Merge settings of the column were not set to uniform.
What is the logic of custom object parameters getting uniform or various as a default setting? It is the worst possible default setting I've ever seen.
2025-12-19 11:57 AM
There's a bug with this at least in AC27. That button that should show up in the header column doesn't show if you have _only_ custom parameters in the list.
Workaround at least for now:
- Add internal parameter (ID e.g.) and make the merging then. Now the ID field has this button appearing. Now you can add some other parameter as well and can delete the ID field from the schedule.
This needs to be fixed!
