2007-09-01 02:54 AM
2007-09-01 10:02 PM
2007-09-04 07:15 AM
2007-09-04 07:34 PM
2007-09-04 07:43 PM
Steve wrote:Have you tried the Cadimage Framing Add-on? From the initial description, it looks like it does a pretty good job with lumber schedules, although I don't know how well it translates into U.S. conventions.
In order to get my schedule for plates in feet and inches I am using .gsm parts.
2007-09-04 09:30 PM
2007-09-05 05:19 PM
Steve wrote:But Golly.... We're using the most mature, comprehensive and expensive architectural CAD program on the planet. Why the heck can't it dynamically change the framing around as walls, roofs and penetrations are manipulated? Wall framing, at least as it is practiced in the US, is pretty easy: only a few rules need be observed and a few optional treatments defined (corners, headers, etc).
The way I do it now, I just paste a pre-modeled studwall into the plan, in elevation view I move the studs, trimmer, cripples and header all as one unit to the proper window location and tweak it a little to match the opening.
2007-09-05 11:10 PM
2007-09-06 04:32 PM
Steve wrote:Kind of facetious, but respectfully so. My point being that AC should have it's own wall framing system. In the US residential market, this type of building is just so pervasive. Here on the west coast, even a lot of the commercial projects use wood frame, cavity wall type construction. Of course, ArchiCAD has the wall framing accessory, which kind of hints at what could maybe be done but like so many things in this program, it falls far short of the sort of industrial strength functionality required to be truly useful and deployable.
I can not tell if you are being facetious or not.
2007-09-06 04:42 PM
