‎2005-12-07 02:44 PM
‎2005-12-08 02:09 AM
‎2005-12-08 02:42 PM
I don't thinkg it is abig deal ttaht the archicad model is started from scratchAnd if we use the SU plug-in to import the "sketch"?
‎2005-12-09 04:54 PM
Walter wrote:Yes, it does.
And if we use the SU plug-in to import the "sketch"? After all, the purpose is to save recreation of work and reduce error. That's my point, does it do that?
‎2005-12-09 06:32 PM
‎2005-12-11 03:59 AM
Walter wrote:Watch out; the plugin assumes that EACH face is converted to a wall, slab or a roof. Therefore, do only one line walls etc - otherwise you will have a hell of a cleanup job in ArchiCAD.
I expect thast if one dresses the SU model with interior walls, floors, windows & add some textures, it will have a high overhead but if at that stage, it can be mostly done by the "field modellers" (read "salespeople"), the clients will have a good idea where thier changes of stock models are taking them, saving as much as an initial proposal by the designers.
‎2005-12-12 08:55 AM
‎2005-12-12 05:40 PM
another Moderator
‎2005-12-14 01:50 AM
‎2006-01-09 10:32 PM
