SketchUp Topic Stale?
Is it because;
People are seeing that SU is so limited that getting a prelim. model just isn't worth it?
The plug-in is a long way from "seamless" so a smooth work flow is not an option.
It's just as fast to prelim in AC
Few design teams need a simple modeller for non-ACers to capture initial design ideas
We are like kids with a new toy, fascinated for a bit but moving on to more fun stuff?
SU seems to offer the simpler front-end to the design process that a lot of sales people etc can use to get client concepts onto "paper". It seems that "modifying from existing home models", as is the case for many home manufacturers, should be simple with SketchUp and communication with the designers a huge step up from faxed napkin scrawls!
17 Replies 17
Erika Epstein
I find sketchup is a particularly useful program for the mucky mucks who can quickly learn it and sketch in it in 3D. Far easier learning curve compared to AC.
I don't thinkg it is abig deal ttaht the archicad model is started from scratch. One goes through the same process translating design sketches.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
And if we use the SU plug-in to import the "sketch"?
After all, the purpose is to save recreation of work and reduce error.
That's my point, does it do that?
Djordje
Walter wrote:
And if we use the SU plug-in to import the "sketch"? After all, the purpose is to save recreation of work and reduce error. That's my point, does it do that?
Yes, it does.
Provided - as always - that you do the SketchUp model in a certain way. It even slices it up into stories - if you defined the stories in the ArchiCAD files - and you can set up the translation properties.
All in all, works quite well. I had trouble with curved elements, but! - from SketchUp 3.1, so I suppose it might be better with 5?
Anyone with any experience there?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanx, Djordje,
This is the feedback I need to keep investing time in an SU/AC workflow.
And SU is very FUN!
I expect thast if one dresses the SU model with interior walls, floors, windows & add some textures, it will have a high overhead but if at that stage, it can be mostly done by the "field modellers" (read "salespeople"), the clients will have a good idea where thier changes of stock models are taking them, saving as much as an initial proposal by the designers.
Certainly better visuals to client early on & less communication errors with the designers.
I will also start to haunt the SU forum.
Again, thanx Djordje & Erika
Djordje
Watch out; the plugin assumes that EACH face is converted to a wall, slab or a roof. Therefore, do only one line walls etc - otherwise you will have a hell of a cleanup job in ArchiCAD.
I also had some curious behaviour - software not reacting to clicks, 3D crashing, and so on ... the team is at work on those, it seems.
Djordje
HP Omen
stefan
As much as I like SketchUp & ArchiCAD, I seldomly combine both... I like to have complete control over the ArchiCAD model I am making, so I usually just model from scratch inside ArchiCAD.
I often go the other way around though: getting a CAD model out of ArchiCAD (but usually into 3D animation software, such as 3ds max/VIZ).
Archicad-user since 1998
my Archicad Book
Eduardo Rolon
Same procedure here, good for quality control of the project.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
I still look for the magic bullet that will do it all.
Once, that dream was to be able to see your project in 3D sometime, somehow.
How far we have come.
I see that I would likely run an AC with the imported copy of SU and an AC with a clean company template to copy, paste or just mimic the model to keep that level of control & chaos that cross-software models often have.
Still better than napkin sketches, blurry faxes or semi-communicated sort-of-likes over the3 phone!
But one day it will be seemless as every software signs on to a standard yet to be agreed on...
well I'm still waiting for my magical computer that will import finished archiCAD models from the design I've draughted out in my head
but.. for the time being, I got this plugin today, and I've just been fannying about, and the whole "each face is a wall" thing is.. well.. quite annoying, I havent taken a look at the user defined rules import feature, but is there a way using this to make it import a vertical surface with a thickness as a wall. in sketch up is I draw a 120mm wide wall... can I set the importer to know that a vertical object of 120mm thickness is one wall? or am I way off base?
cheers,
dan
