Rick Thompson
Something new and exciting sounding.. ArchiQuant
I just ran across ArchiQuant by Cigraph. It does quantity takeoffs and estimates. This could be a home run, and out of the park if it works as needed, which it must or why do it. I am going to play with it, and it looks great, but should take awhile to figure out.
If anyone has used it, or Cigraph is listening in, I have a little script I use to convert the objects (rafters etc) generated from the roof wizard that takes the unusable lengths Ac spits out, and converts them to standard lumber ordering lengths... 2x10x10, rather than 2x10-x9'-3.33333". This is essential for a usable bill of materials. How many 2x10x12's to order, versus a poop load of 2x10x of many different inches that translate into 2x10x12's.
The only way I know to do floor framing is to manually place (multiply/drag copies) for all the joist. I key and quantify these by the ID's (2x10x10, 2x10x14 etc) I assume ArchiQuant will organize all the lumber by ID's? If I could get the info on the screen shot to look like it does in the spread sheet, without having to use the spread sheet, I would be a happy camper.
This is very exciting. The first thing available to generate a bill of materials other than the failed GS's ancient built-in version.
I am also assuming this means AC has committed to not doing any development along this line.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
39 Replies 39
Steve Jepson
Looks very good. I hope it works but I am skeptical because they do not even show a sample of what there material lists looks like in the brochures.
They only talk about what it could do if you fussed with it long enough.
They need to show a simple framing model and then show us the material list they were able to make from it. We could tell a great deal about it from a simple example like that.
Rick Thompson
I gave it up. It seems you need to relink the database parts to the intended component manually each time. If you have say, an interior wall, each wall would need to be injected from the one wall you set up into every instance of that wall, and start over on another pln. With property scripts assigned you just place the wall and go on. Open another project and you don't need to do anything. Unless I am missing something that is a huge deal killer. I couldn't get my old AC tweaked database to import in chapters, so I ended up with an unusable long list of data. Maybe that was my error.
So, I gave it up. I never got to try and see what would happen with the rafter lengths since it was way too much trouble to work with. Maybe it is fine if you just occasionally need to set something up for a unique project, but it seems unusable for any template based work, as far as I can tell. I was trying to get a response from Cigraph, but I didn't.
O'well. Maybe you are having better success?
Rick Thompson
Mac Sonoma AC 26
Rick I am sure you have looked at http://www.encina.co.uk/framewright_pro.html. Looks like it does what you need and nicely at that. After all Ralph is behind it. Let use know what comes out of you quest.
Joseph
KeesW
Joseph
I am also looking at ArchiQuant because it might do exactly what I want - if it works. I've tried to open your suggested link but get a 'not available' message.
Kees
Cornelis (Kees) Wegman
cornelis wegman architects
KeesW wrote:
Joseph
............. I've tried to open your suggested link but get a 'not available' message.
Kees
You are right! this link http://www.encina.co.uk/framewright.html gets redirected to Objective!
We have to get some clarification from Ralph (the creator of the great Encina)??
Joseph
Ralph Wessel
Hi Kees,
The link had an extra dot at the end - try this: http://www.encina.co.uk/framewright_pro.html
Ralph Wessel BArch
Central Innovation
Hi Rick
I am also very interested in ArchiQuant, but there is not much info out there on this product. You get the basic manual at the Cigraph site, and thats it. No users back feed.
My question is: The problem you mentioned, would it not be solved if you used favorites? I mean, every wall you use on a NEW project you just use a Fav, with all the Archiquant data in it.
One more Q: Is there any problem in opening an Archiquanted file on an AC without Archiquant? Will this give you an error?
Thanks in advance
Rick Thompson
Krippahl wrote:
Hi Rick
Thanks in advance
If you are starting from scratch, that should hold true. Personally, I doubt the long run development, and then you end up with another issue (new AC releases). Even with Favorites, you still have too many objects etc to laborious manage. Despite AC's archaic interface (basically the same since 4.5 when I came in) linking via property objects works great, and is automatically picked up. Another issue for me is I continuously evolve plns (stock plans), so ArchiQuant's manual setup is useless to incorporate into an existing pln. I actually could not be my data base to import in any useable manner, so that too was an issue. As you said, their info is lacking. Personally, I would not waste time and go ahead and learn AC's calc function. It really works fine, it is the abysmal lack of useful formatting tools, and the prehistoric panels (nothing is adjustable) that are my main issues. It is hard to imagine GS will ignore it forever, but I would not expect much change, and no time soon either.
Loading it and not using it shouldn't be a problem. However, removing it (as with any other add-on you might try), is pure hell to get rid or that "you are missing an add-on" warning for every file you subsequently open.
Rick Thompson
Mac Sonoma AC 26
Maybe the usefulness of Archiquant depends heavily on the construction system you use.
In your case, working on the North American market, you need all those quantities from the wooden structure.
In our market (South European), buildings are made of concrete and bricks, mostly, so quantities are related, for instance, to square meter of composite wall.
It seems to me that, in this particular market, Archiquant would be an excellent tool to have preliminary costs, during design development phase.
Of course you must be right on the "you are missing an add-on" virus, because I get that a lot on older projects I used Architerra with.
I tried to learn AC calc function, even bought the "From CAD to quantity survey", but never managed to. Need to upgrade my brain I guess.
The real problem is, I don't need a quantity survey per se, but a simple formula that lets me know, at any given time, how much the building I am currently designing will cost to build. Something simple and fast. Thats why I am so interested in Archiquant.
