2017-01-05 08:37 PM
2017-01-06 03:31 PM
ares997 wrote:try to send to archicad. before doing that mark a point on revit project that you will know its coordinates in lat lon or wgs84
Team:
I am attempting to coordinate a model generated in Revit 2016 that is on State Plane with a model created in Archicad 20 that is modeled close to the Project Origin. The issue that I am having is that there doesn't seem to be a way to accurately export the Archicad file located in State Planehttps://en.wikipedia.org/wiki/State_Plane_Coordinate_System .
The goal is to be able to consistently export a model out of Archicad 20 that is relative to State Plane Coordinates so that I can generate single model that are referencing two files in either Navisworks or Solibri.
Any suggestions on how to achieve that would greatly appreciated.
2017-01-06 05:47 PM
2017-01-06 06:00 PM
ares997 wrote:
That doesn't seem to solve the issue. Even when I open the IFC file that was created in Revit it is brought in at an arbitrary location that isn't necessarily relative to State Plane.
The issue surfaces when I try to bring in the two models into Navisworks. One is located on State Plane Coordinates the other from Archicad is 2million feet away from that location.
2017-01-06 06:02 PM
2017-01-06 06:16 PM
2017-01-06 07:25 PM
2017-01-11 03:15 AM
2017-01-11 05:35 PM
2017-03-21 09:52 PM
