Story Settings in Teamwork
After setting up a small residential project for teamwork, I“v encountered a small problem. I need to change the story settings; more precisely, add 10cm to all the stories. I“m not able to do that! Even as team leader, the settings remain the same, and are note editable.
How do you go about changing them then?
TomWaltz
Some settings, such as story heights, require "Team Leader with Exclusive Access."
I know there are others, but my major sugar high from lunch is blocking my memory...
Tom Waltz
Yes. Thanks Tom. That was the only way I could change it. Pity though. You have to change all collaborators workspace just for that....
TomWaltz
There is a general theory of Teamwork: Only one person can ever change something, and you can never change something that COULD change something in someone else's work space.
For example, if you change the dimension rounding settings, it could change dimensions that are in someone else's work space. Therefore, you can only change the dimension settings when you have Exclusive Access.
Now thinking about it, I believe Layer Intersection priorities may fall into that category as well.
Tom Waltz
