‎2019-11-20 10:37 AM
‎2019-11-21 03:25 AM
‎2019-11-21 11:50 AM
‎2019-11-21 12:41 PM
famadorian wrote:Only slightly more useful than the Open & Repair option then! At least you get a reference for the missing elements. Just a suggestion but it may be worth running Open & Repair which may fix the database references. If errors are found it is probably worth saving a new copy of the file as I just found one of my views with everything intact apart from the repaired element in the model which had vanished. Thankfully I have a limited number of drawings to check.
When exporting IFC, I get a bunch of these.
Is there any way to figure out which object corresponds to these identifiers?
The following elements could not be exported due to missing geometry:
1KLfMRQZLE3gfA1Pl8G3ca
0j40ZCeoTDkR6mnsqUToM4
