2018-11-25 12:50 PM
2018-11-25 06:34 PM
2018-11-25 11:00 PM
poco2013 wrote:
I don't know of any way to do as you suggest? Properties are restricted to a single element only and their available parameters only return a single value or record.
An alternate to consider would be to add a property to each wall type with which you could add the info - thickness, composite, position, etc. in manually, then "dig" that out in your expression. OR, you could embed that info in the description of your composite and knowing the position of that info, use that in your calcs.
The new Python feature, maybe next year or thereafter, may provide some relief, but Graphisoft is not that far thinking and this does not seem like something they would make available outside of the API.
2018-11-28 04:07 PM
2018-11-28 08:33 PM
ash4ever wrote:There are no doubt other solutions for (heat loss calculations) based on what you are
I need it for the heat loos calculation using materials' properties. If you have other solution, please tell me it🙂 ![]()
2018-11-28 10:49 PM
