ā2018-06-25 05:07 PM
ā2018-06-25 05:28 PM
ā2018-06-28 03:51 AM
ā2020-04-24 12:14 PM
LaszloNagy wrote:āeasy to do in ARCHICAD 22, if you have it).ā Can you tell a little bit more specific? Thank.
If you generate a section through the Window you will see that the Wall Closure is not generated in 3D, only in 2D. Therefore it is not calculated either. I think you will have to do those calculations (easy to do in ARCHICAD 22, if you have it).
In AC21 you would have to do the calculation within the Window objects, which involves GDL scripting.
ā2020-04-25 05:49 PM
The painful and cumbersome workaround would be to schedule this separately in a window schedule where I have to list the height, width and reveal depth and then do the math.
