In that case you can download the 30-day Trial version of AutoCAD 2009 and save a DWG file from it which has all the standard Hatches, Line Types etc. in it.
Then you can use it as a Template File.
I can actually recommend Template Files because with its use a very good data exchange channel can be established between ArchiCAD and DWG.
