Why Zone Parameters: Wall Inset ... Surface are zero?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-04-21 11:32 AM
Why Zone Parameters (Wall Inset Side/Top/Back Side Surface) are 0.000 on this plan?
Thank you.
- Labels:
Data management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-22 08:55 AM
Victor wrote:Check what is your setting in Options/Preferences/Zones for the Wall recesses. If the recess on the plan is smaller that the values specified there it will not be included.
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-22 06:48 PM
Djordje wrote:Victor wrote:Check what is your setting in Options/Preferences/Zones for the Wall recesses. If the recess on the plan is smaller that the values specified there it will not be included.
See my setting. Why?
www.archisafe.com/err_zones.gif
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-26 08:35 PM
Victor wrote:Hm. Funny.
Your zone should "flow" into the space if you place a door. Try that. It might be because you are using a window, and the sill exists; therefore, the VOLUME of the room is changed, but the AREA is not.
What is the setting of the window area that is to be excluded from calculation? Usually it is 1m2, try a larger window.
Try also specifying a very small value in the "if larger than" fields.
Did not try, will check.
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-27 09:02 PM
See quoting from Archiguide and my test on www.archisafe.com/err_zon/index.htm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-28 03:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-28 03:04 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-28 03:07 PM
What you enter here has a profound effect on what will be displayed for these values, because the depth of the Wall Inset is calculated from this.
So maybe you have a wrong GDL expression here which gives wrong Wall Inset Depth to the program, and therefore those 3 Wall Inset values will be incorrectly calculated.
Actually from the amount the Zone flows into the Wall Recess you can see whether this Wall Inset value is correct or not.
On your first image, it looks like your Zone does not flow into the Wall recess, so probably it is a problem with this field.
Check other Windows/Doors in the GS Library and copy-paste the formula from those - it should help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-28 03:10 PM
It goes like this :
Wall Inset Side Surface
Type: numerical (positive value)
Possible range: 0 and up (in square meters)
Returns the total of side surfaces of the wall inset, which is the size of the two sides of the rectangular hole the Door/Window cuts into the Wall. It is obtained by multiplying by two the product of the depth of the Door/Window in the Wall and its width.
The correct text should be this:
Returns the total of side surfaces of the wall inset, which is the size of the two sides of the rectangular hole the Door/Window cuts into the Wall. It is obtained by multiplying by two the product of the depth of the Door/Window in the Wall and its height.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-04-29 08:21 AM
The problem was in Parapet Wall Inset on/off (Window Selected Settings)
Too many parameters influences a Wall Inset ... Surface
1.Parapet Wall Inset on/off (Window Selected Settings)
2.Depth of Inset (Window Selected Settings)
3.Frame Thickness (Window Selected Settings)
4.Reveal (Window Selected Settings)
5.Add Wall Recesses to Zones (Preferences)
6.Derived Sizes (Detail)
7.Type of a window
and others
May be that is very difficult
I am not so pleased, but I have grown wiser
