2016-10-25 06:04 AM
2016-10-25 08:22 AM
2018-02-26 12:48 PM
2019-11-05 01:54 PM
2022-03-07 12:00 PM
I am having the same problem with Archicad 25. It fails to determine the correct opening orientation (Left or Right) even if I break the mirrored hotlinks!
Moreover, the View from Opening Side is also faulty.
2022-03-08 02:07 AM
Could you show some screenshots about the hotlinked elements, Scheme Settings and generated Schedule values so we can see the exact situation?
2022-03-08 11:01 AM
I am using a single Archicad file with mirrored hotlinks pointing to itself.
I have included both windows and doors in the schedule.
Doors have the opening orientation correctly indicated and they are correctly drawn in the View from Opening Side, but many windows are faulty in both columns.
Look in the screenshot at window type F-1: the quantity per opening orientation is wrong and the View from Opening Side is also wrong: both Left and Right orientations are drawn the same.
I can also send you the Archicad file via e-mail if that is useful.
Thank you!
2022-03-18 11:56 AM
My question is if Archicad is displaying reliable information regarding the windows opening orientation and View from Opening Side. With hotlinks it clearly wasn't (what if we hadn't noticed this and sent the schedule for production?)
Working on large projects requires a lot of work to fix this.
