‎2021-03-17 08:00 PM
Solved! Go to Solution.
‎2021-03-20 02:12 PM
‎2021-03-20 02:16 PM
‎2021-03-20 02:21 PM
rob2218 wrote:
So...here's as far as I got?
I'm not sure how to go any further than here......
LEN( Element ID)Currently, you define "ID_Length" to be equal to "ID_Length", which is itself, which of course cannot be evaluated as an expression. It has to be dependent on something else, and that something else is calculated by taking the "Element ID" text parameter of the element, and calculating its length (how many characters it is - this is what the "LEN" function does). The number of characters in the "Element ID" parameter is the value the "ID_Length" Property returns.
‎2021-03-20 02:25 PM
rob2218 wrote:
I guess as a quick sloppy fix...I could do this using "fills" as a masking tool in front of these fields?
‎2021-03-20 03:59 PM
‎2023-03-15 09:20 PM
ALL:
There is a much easier way to get the AA, BB, CC...to the end of the schedule, All you have to do is enter the AA as "aa", i.e., not capital.
