rob2218 wrote:
ok Barry, I've tried to add a "period", a "space" an "aesterick" and nothing seems to push the double letters to the back. I'm stumped.
Just tested and a period or underscore (but not a space) in front of the single letters keeps them at the top, pushing the double letters to the bottom. Unfortunately, you have to look at the period or underscore in the schedule and any labels that contain the ID.
The other old, tried and true method is potentially error prone due to data entry error and changes and relies on manually entering a sorting code in an extra field of the library part. You use that sort code, perhaps combined with the ID, to sort the schedule, but change the column width so it doesn't show.
For your particular case ... single vs double (and maybe triple etc) letters ... the relatively new Property Expressions are the best solution. You get your cake (the ID's look the way you want everywhere with no funny extra symbols) and get to eat it too (the sorting is your way).
Will start a fresh post for the details - but the idea is you create a new property for openings - and the value of that property is the length, in characters, of the ID string: 1 for "A", 2 for "BB". Then, your schedule includes THAT new property as the first sort, and the ID is the second sort. Thus, all 1 character IDs will be grouped first, then 2 character IDs, etc.
AC 28 USA and earlier • macOS Sequoia 15.3, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
