Window head height relative to story height
Does anyone know if it is possible to extract the head height of a window relative to the story height? The only parameter I have been able to pull into the interactive schedule is the head height from wall base. Thanks.
3 Replies 3
LiHigh
Sadly no.
It should be possible but GS screw up on this one.
Howard Phua
Win 10, Archicad 19 INT
Aussie John
i havnt tried it but can you make a parameter which gives you this value then add that to the schedule?
Cheers John
[/size]
Aussie John,
I believe that would work but you would need to add this parameter to each and every window part you are trying to list....
Dan K
