Window head height relative to story height
Does anyone know if it is possible to extract the head height of a window relative to the story height? The only parameter I have been able to pull into the interactive schedule is the head height from wall base. Thanks.
LiHigh
Sadly no.
It should be possible but GS screw up on this one.
Howard Phua
Win 10, Archicad 19 INT
Aussie John
i havnt tried it but can you make a parameter which gives you this value then add that to the schedule?
Cheers John
[/size]
Aussie John,
I believe that would work but you would need to add this parameter to each and every window part you are trying to list....
Dan K
