2008-10-23 11:21 PM
2008-10-24 10:32 AM
2008-10-24 12:24 PM
2008-10-24 02:00 PM
2008-10-26 05:02 PM
2009-01-08 12:25 AM
2009-01-08 11:12 AM
2009-01-08 10:22 PM
LINZ wrote:I believe that all you need to do is specify the correct drawing units when you import the file. These will be the units set in the DWG file itself so if metric they will probably be mm or m. If you use inches and it was set to mm the model will be 25.4 times too big so it's easy to figure out if the first try doesn't work.
How do I place a metric DWG from a consultant into an imperial Archicad PLN at the correct scale?
2014-01-14 02:20 PM
2014-01-14 02:37 PM
