Indeed, this might be an option, but what I have discovered is surprisingly simple and effective
GREAT !
What I did was:
1. Importing dwg to the story in 'Project Map' - NOT TO THE WORKSHEET !!! Set the scale of the story to 1:500 (or whatever scale you want) - the dwg is perfectly readable. Dipslays exactly as I see it in autocad and exactly how I wanted it to be displayed (btw. I use draftsight, instead of autocad - free alternative of autocad).
2. Copy and paste to the worksheet set to the same scale - 1:500. If you have a dwg from land surveyor (like myself) you are ready to go with master site plan. if you change the scale - the text on the dwg changes as well, but your desired scale (and the way the text is displayed) is at the 1:500 scale - as you wanted.
Now you have all the benefits of archicad and the way it changes the scale automatically. You can change freely the way, the dwg is displayed. The dwg is not exploded. If you modify it in any way, it gets immediately updated in beloved Archicad
Oh, I am so glad ejrolon, that I was able to show you something, you did not know
All the best of luck in your professional life - thanks.
