Zone/Room perimeter without doors width
Michal Forejt
I'm trying to get the perimeter of the room in my interactive schedule but without the width of doors.
I have found this thread: http://archicad-talk.graphisoft.com/viewtopic.php?p=174371
Basically I think I need to create new parameter and put simple calculation ROOM_NET_PERIMETER - ROOM_DOORS_WID. But I have no idea where to change the sript of zone stamp. Could anyone point me to some tutorial or help me on that?
Thanks
ArchiCAD 27
WIN 11
AMD Ryzen 5 7600X 6-core
64 GB RAM
NVIDIA GeForce RTX 3060
You should be able to select an instance o the the zone stamp and go to File > Libraries > Open Library Part (command+option+O). You should save your custom stamp under a different name. If the one you are using is a default part it may be locked in which case you will have to do this anyway. You will then need to assign the new part in your zone definitions.
Michal Forejt
Well, this is clear to me. Where I got stuck is where exactly should I put the formula in the script...
ArchiCAD 27
WIN 11
64 GB RAM
Here is what I found with a search:
http://archicad-talk.graphisoft.com/viewtopic.php?printertopic=1&t=33308
Please let me know if this works.
