archicad 12 conversion to dwg file from layout
i had a problem when exporting the archicad drawings to autocad from layout book with 1:200 scale,i.e. i opened autocad file when i measure the drawing all the dimensions are converted to scale.
what is the exact scale settings for 1:200.
if not possible in AC12 higher version will do.
please help?
What exactly are you experiencing when you open up your drawings? Are you opening the drawings up in autocad and finding that known measurements are not correct? Its probably a setting in your translator.
i know it's transalator settings.but what scale settings will do when i saved my plan(1:200) from layout to autocad.
Please answer the questions asked if you would like to receive further help.
