archicad 12 conversion to dwg file from layout
i had a problem when exporting the archicad drawings to autocad from layout book with 1:200 scale,i.e. i opened autocad file when i measure the drawing all the dimensions are converted to scale.
what is the exact scale settings for 1:200.
if not possible in AC12 higher version will do.
please help?
3 Replies 3
What exactly are you experiencing when you open up your drawings? Are you opening the drawings up in autocad and finding that known measurements are not correct? Its probably a setting in your translator.
i know it's transalator settings.but what scale settings will do when i saved my plan(1:200) from layout to autocad.
Please answer the questions asked if you would like to receive further help.
