door not showing in plan
Stephen Dolbee
Does anyone know why a door (d&w builder) does not show up in plan, but does in elevation? Just a dot and the opening appear. This plan was started in windows on a pc, but I am now using a mac. The door appears in plan on the pc.
This is strange. Even if I draw a new wall and try to insert a door, it shows only the opening. This only happens on the lower level plan. Doors seem fine on the other levels.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
5 REPLIES 5
Could you attach a screenshot of the problem?
Sounds like a story setting or floor plan cut plane issue.
Maybe the Home Story Setting as well
Screenshot would help alot
Cheers
Nuge
Cadimage are aware of the problem and will be fixing soon,it only happens on a storey with a negative number
Cheers Nuge
AC27 i9 11900K / 128G ram / GTX 3090 / D5 Render
Stephen Dolbee
Thanks, Nuge. Work has been so slow, I haven't even started a new job since I got my new Imac in Dec. (probably a bad time to invest in new hardware). Hopefully the problem is fixed soon.
