fevzi19
dwg export wipeout
I want to display the background hat as a wipeout in Archicad 29. Is this possible? In the PDF, one object doesn't show up underneath another, but it does in AutoCAD.
4 Replies 4
marcoariveross
Hi
It's just a DWG translator configuration.
You could try outputting it as is.
BIM Manager Pavimaq
Lima-Perú
Archicad 29-Windows 11-64Gb RAM
If you the background fill with the pen -1 it will produce a wipout.
Versions 12 to 29
AMD Ryzen 5700x, 32GB RAM, RX580 8GB
Windows 11 & OS X Monterey
Intel Core i7-13700KF, 64GB RAM, Nvidia RTX 4070 SUPER 12GB
Windows 11
Kpetrocheilou
What about slabs with holes? In this case wipeouts are not produced, and doesn't produce any other fill either. It looks like wipeouts do not recognise "islands" in the way hatches do.
Do you have any suggestion so that export to dwg looks more like the drawing from AC?
AC29.0.1 INT FULL, Windows 11 Pro
What kind of holes? Manualy made poligonal holes?
Have you tried the Opening Tool? I'm refering to the one added in AC23, not the window or the door.
Versions 12 to 29
Windows 11
